Old 05-06-2016, 03:45 PM
Shiner's Avatar
Shiner Shiner is offline
Exclamation BIG PROBLEMS- RideTech MuscleBar
My muscle bar seems to be too long
I took some measurements and I need to compare
Factory Front Frame Rail Width is 41 3/8"
Mine measure 41.5" (even better for this situation)
The bar has welded bushing retainers in each end about 4.5" from the ends
The Inside Welded Washer to Washer Width = 29" is this right???
The sway bar seems to be either welded wrong or the bar is the wrong length. Please help.
Need some help here. Pretty concerned.
1970 Chevelle SS
408 Forged LSX, LSA Blower, 4L80E, Ridetech HQ, Baer Brakes, Weld S71b
1997 Dodge Viper GTS
Heads, Cam, Bolt On's, BBS Wheels, Moton Suspension
Old 05-06-2016, 04:29 PM
is it possible that you have the bushings and such on the wrong side of the welded washers....?
Old 05-06-2016, 04:31 PM
Shiner's Avatar
I asked RideTech and he said they are to be on the outside. I can understand why as it keeps the bar from walking
1970 Chevelle SS
Old 05-06-2016, 05:01 PM
Shiner's Avatar
My Savitske frame brace went in without drama. I don't understand why this is happening to me
1970 Chevelle SS
Old 05-06-2016, 06:12 PM
Get some better pics and send them to ride tech or post them on here
Old 05-06-2016, 06:22 PM
Shiner's Avatar
Here's another
1970 Chevelle SS
Old 05-06-2016, 06:44 PM
dhutton dhutton is offline
Are the guys at Ridetech helping you? They can supply you with the dimensions etc you need.
Don
Old 05-06-2016, 06:54 PM
Shiner's Avatar
They said they would get back to me Monday when I called to day. I think they were hosting an event and were busy. Bummer for me.
1970 Chevelle SS
Old 05-06-2016, 07:32 PM
Shiner's Avatar
The instructions state the bar is 38.75 Total Length. I confirmed this length.
I don't understand my frame measures factory spec, it doesn't fit. This is a nightmare. What sway bar will the strong arms work with?
1970 Chevelle SS
Old 05-06-2016, 07:51 PM
SSLance's Avatar
SSLance SSLance is offline
Is the other side bolted up in those pics? I don't have a 70 Chevelle, so measuring mine won't help. It's either something simple or they sent you the wrong center piece. See if it'll line up with the bushings on the outside of the alignment rings?
Lance
