Old 03-02-2005, 08:29 AM
Payton King's Avatar
Default Sound and Heat deadening
I know that this has been discussed other places, but I am at the point I need to make decisions on sound and heat insulation. Someone told me that www.lizardskin.com was a good product and so was fat mat. Any of you out there with real life expierence that can direct me.
On a different, but congruent note. Anyone know if I could spray "Line-X" or "Rhino Liner" under the car. I think the protection would be great, but I am a little concerned that the heat from the exhaust might melt it. My entire system will be coated so that should help with the heat some. It is also going to run very close to the pans as well.
Thanks in advance for your input.
Payton
Old 03-02-2005, 08:41 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
I know folks who have had bedliners sprayed underneath with good results although I don't know what the clearances were with their exhaust system. I painted mine and in some areas where my pipes run < 1/4" to the floor, I put some self-adhesive thermo-tec (from Summit, etc.) and it's held up well for 3 years now. It's supposed to reflect 9X% of heat away. Seems to work.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 03-02-2005, 09:17 AM
c.schulz's Avatar
c.schulz c.schulz is offline
Lizard skin is a good product but consider a product that can be serviced.
In other words,what if you need to make a change to the car and cut or weld something?? The sheets of sound deadener are much more easily removed then spray ons.
Fat Mat is a much cheaper product than dynomat.Look for it on ebay.Or get a hold of Steve1969LS1 over at PT. Good man and very helpful.
Chris
71 RS Pro-Touring thing.....will it ever be done?? Not with out a second mortgage! SOLD
Old 03-02-2005, 10:08 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I too would recommend a mat type. Fat Mat is pretty cheap, and is probably just as good as any other.
If you want heat insulation, I'd use a layer of that foil backed insulation material on top of the sound deadener. Most interior shops have it. It can also be bought at Home Depot.
Old 03-02-2005, 10:49 AM
Default Thanks
That is what I needed to know. If anyone has an opinion or real life expierence feel free to chime in. I did not think about needing to repair something with the spray in stuff.
Old 03-02-2005, 10:59 AM
Jay Hilliard's Avatar
Default Dynamat
Payton,
I used Dynamat Xtreme. It was easy to use and apply with their roller. You can buy it on ebay for $100-110 for a case which covers 36 sq ft. Enough to do the firewall back to the rear seat area.
Jay
Jay
Old 03-02-2005, 11:46 AM
Default Jay
Thanks Jay. How far from Charlotte are you?
Old 03-02-2005, 01:22 PM
zbugger's Avatar
zbugger zbugger is offline
Try sending a message to Andrew B. over at PT.com regarding Cascade stuff. He's had good experiences with it. I on the other hand am still doing my own research.
Old 03-03-2005, 07:06 PM
spaztikatik spaztikatik is offline
I put a post up about 3 or 4 weeks ago about using B-Quiet, they're out of canada. Really awesome stuff, different kinds of sound deadening materal for different areas of your car, it all depends on how quiet you want it to be inside! Plus it's cheaper than X-Treme, so i'd say give it a shot? I love it.
Old 03-04-2005, 08:27 AM
Default B-quite
Do you have a web address?
