Old 05-09-2016, 03:11 PM
Tony V Tony V is offline
Default Holley HP and MPH
What are folks using to read MPH in the HP system? curious to understand how and possibly use it for my PWM controller for my fans.
Thx Tony
Old 05-11-2016, 09:28 AM
gray86hatch gray86hatch is offline
What trans. It will work with almost any input just have to create the input strategy to control your fan output
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
Old 05-11-2016, 09:57 AM
I have dominator but using VSS for speed in my system. Will setup the fans against speed/temp/ac/etc.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 05-11-2016, 11:13 AM
Tim
using a tremec 6 speed.....currently my fan is working but only using CTS temp, i'd like the option to turn them off at a certain MPH.
Old 05-12-2016, 04:46 AM
How many of your inputs do you have left with the holley?
Do you have the vss sensor on the trans? Can wire it into Holley for the mph signal and set conditions against that.
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 05-12-2016, 08:53 AM
yes, i've got a VSS sensor, i'm currently only using one output and zero inputs so I have plenty of I/O room. although i was using the VSS to drive my speedometer and not sure if I could "split" the signal to both the speedometer and HP.
I also read that VSS sine wave couldn't be read by the HP, that i either needed to convert it to a square wave digital signal or find use a different sensor that outputs a digital signal. not sure if there's any truth to that....but i can try.
thx for the input
Old 07-16-2016, 08:09 PM
andrewb70's Avatar
The HP can't use a stock VR style VSS, only Hall effect. The Dominator can read both.
Andrew
Old 07-18-2016, 07:49 AM
Andrew
Thx Andrew......i'll bag the idea for right now.
Old 07-18-2016, 07:53 AM
Just touching on this, do you need to reference the speed? If it's PWM, just have it turn down as it approaches desired temp. As speed increases, temp will drop and the fans will as well without needing to reference the VSS.
Just a thought.
William
Texas A&M BSME 2008
1992 Corvette ZR-1
Old 07-19-2016, 05:52 PM
Just a thought.
William
I was going to control the fan speed with CTS and Speed but getting a speed signal to the HP wasn't in my scope. right now its working based on temp.... a simple straight line slope as its getting hotter the PWM % increases.
