Old 05-18-2016, 10:18 PM
SuperB70's Avatar
SuperB70 SuperB70 is offline
Default New style wiring system and monitoring app for OIS and Google
Two of my good friends have join forces and now we have a awesom product in the market. Both can be found from Facebook.
Here is a little bit of them.
SP Leinonen ltd has new style wiring system that doesent need normal fuses or relays. All done by electronics. Normal car system has 36 channels and custom configuration can be done. Weight is 1 kg / 2lbs.
Has one master and two slave units. Between them is a BUS cable and
Data can be send two ways. Any normal electrical function will work and custom need can be done. This will be unveil in US in a one special car at coming carshow. More that later date.
In my project witch I will soon unvail here will have these and it will have all kind of custom apps in it. One off tablet gauge cluster, all switches will be replaces with photoreasistic virtual switches in touch control form in a tablet computer.
Active air suspension, active rear spoiler, on/off select ABS brakes, adjustable traction control, just a few.
Napko ltd jas a monitoring application for Ois and Android so you can desing your own gauges and turn your phones or tablet to your gauges.
Napko Ltd/RealDash development team has joined forces with SP Leinonen Ltd to produce fully configurable vehicle electronics solution. This setup allows to control vehicle headlights, flashers, heater, and other systems directly from your touch screen device, no physical switches are necessary for the installation.
In addition to custom vehicle installations, this setup is suitable for marine applications, and heavy machinery.
Entire setup will be publicly available during 2016. For any custom/prototype installations, contact RealDash team or SP Leinonen for more details.
, Juhani
