Go Back   Lateral-g Forums > Vendor Specific Technical Discussions and Support > Speedtech Performance USA
Old 05-23-2016, 12:01 PM
Ben@SpeedTech's Avatar
Default Widened Camaro front inner fenders available!
Hey All-
To go along with our new ExtReme front subframe we are now offering widened front inner fender wells to accommodate the wider 315mm tires and huge steering angle. These tubs have a lightweight and sturdy fiberglass construction and a semi gloss black gel coat finish. Check 'em out by Clicking here!
-Ben, Creative Director
Old 06-16-2016, 04:01 PM
You ca see here how the tubs make a difference and fit the profile and dimensions of the ExtReme frame rails. Here are a couple pics of Roger's RedZed 69 Camaro's old tubs and it's new ExtReme tubs...
Old 06-16-2016, 08:19 PM
Sonar Chief's Avatar
Question
Ben ... those look awesome, question, how do they mount? Stock hardware?
Thanks, I'll need a set for my 67 Camaro, are they in stock?
Michael
Old 06-17-2016, 03:58 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Hmmm. I'm very tempted for my 68!
Edit. Since these are designed for the Extreme subframe which I'm not running I have a couple of questions. Do these sit on top of the subframe in all places or does any part drop below the top of the subframe along the outside of the frame like OEM inner fenders? Assuming the latter what is width of the extreme subframe in those locations?
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 06-22-2016, 02:46 PM
Sorry I missed these posts, I'll get some installed pics and get 'em posted up as soon as I can.
Old 07-22-2016, 11:25 AM
Question
Ben ... still waiting on installation pics or instructions. Any pics of Roger's car?
Thanks,
Michael
Old 07-23-2016, 09:25 AM
Blake Foster's Avatar
I will have him post up some on Monday. they look really good installed.
just sent off the 67-8 set to have molds made and a production set to test fit.
will be a couple weeks for those
Blake Foster
www.speedtechperformance.com
Old 07-23-2016, 10:50 AM
glassman's Avatar
glassman glassman is offline
Blake or Ben, two questions:
For my 2nd gen, I currently have a powder coated stitched welded g braced semi stock front clip with your control arms and Baer spindles and brakes.
A-do you have these for 2nd gen yet?
B-if/when I upgrade to your new front clip assembly will these fit?
Thanx, mike
Mike
Old 07-24-2016, 11:35 AM
Thanx, mike
A. No
B I have no idea. the 2 gen inner fenders have alto more room than firs gen, the one we had here (Rodgers from Ironworks) looked like only the rear inner part of the fender would need to me modified a bit to clear the tire at full turn. because the fenders are wider outside than a 1st gen you don't need as much BS OR you can run a larger tire I think (not confirmed yet) that a 335 will fit with no outer fender mods.
Blake Foster
Old 07-24-2016, 06:54 PM
glassman's Avatar
Originally Posted by Blake Foster View Post
A. No
Thats what i was thinking. I'm only trying to get a 295/305 18 up there. Did u use this p# on rodgers and modify it? if so, i'll most likely get a set sometime in winter.....thanx, mike
Mike
