Old 05-31-2016, 07:37 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Default 1972 Camaro Sub frame, complete rebuild, all new!
Item Location (City/State): Northern California/ Dixon
Price: $2500.00
Description:
Price: $2500.00 Pick up only, no parting out. ($3640.00 retail)
Possible trade for LS stuff or T56
All parts are new, completely assembled, no hubs or brakes on the subframe unless we make a deal with the 6 piston wildwood kit (black caliper). Its the budget big brake kit. 1100.00 retail I believe. All parts add up to $3640.00 minus the grade 8 allen fasteners used to assemble. Going a different route, not looking to get rich!
Stock 1972 Sub completely stripped, seams welded, PC gloss black. $400.00
New Chassis Works G Street suspension w/ coil overs $1698.00
https://www.cachassisworks.com/p-118...uspension.aspx
New 1 5/16 G Street anti roll bar w/billet mounts $339.00
https://www.cachassisworks.com/c-325...gm-f-body.aspx
New Bump steer, center link and idler link kit (chassis works) $545.00
https://www.cachassisworks.com/p-126...r-arm-set.aspx
New Power 600 Steering Box 12:7:1 (99% sure this is the one I bought) w/ new pitman arm. $658.00
https://www.cachassisworks.com/p-110...1271-rati.aspx
I will throw in the DD steering shaft that is cut to length for the solid steering shaft setup like Cyborg TT's gen II (eliminates rag joint's). The u joints will not be included.
Thanks,
Kevin
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
