Old 06-18-2016, 08:18 AM
out2kayak out2kayak is offline
Default Lt4
Has anyone installed / run a LT4 (GM part number 19332621)?
I see them for $12K and with 650hp / 650lb-ft it seems like an interesting offer, especially with a warranty.
Something like:
http://www.karlperformanceparts.com/...olet/46460/566
Just curious how the install went and what you think of the engine verses an LS.
-- Joe
Old 06-18-2016, 06:57 PM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
Looks like the complete kit with harness and accessory drive system is about $15,000 vs about $12,500 for an LSA. Keeping in mind accessory drive for the LSA is not included. It's definitely interesting for that close of a cost. I won't what else would be needed to complete the install.
Kyle
Old 06-19-2016, 07:34 PM
CarlC CarlC is offline
Dry sump external tank, hoses, etc. + adequate fuel system + cooling = another likely $5k.
http:www.vaporworx.com
Old 06-19-2016, 07:41 PM
I figured the fuel system and chilling would be pretty similar. Not sure about a heat exchanger for the SC. I saw their $15000 kit for the lt4 was a wet sump. I didn't really read into it much so I might have missed something.
Kyle
Old 06-20-2016, 09:02 PM
novahollic's Avatar
novahollic novahollic is offline
Keep in mind that the LT1/4 engines are direct injected, so modifying/tuning is going to be a bit of a different ballgame.
No doubt these are awesome engines, but there is going to be a learning curve coming from the LS platform.
