Old 06-22-2016, 03:09 PM
Ben@SpeedTech's Avatar
Default Speedtech releases new stronger Frame Connectors!
Our new frame connecters for '67-69 Camaro are now in stock and are available to order! These are designed to be stronger than any other design, strengthening the car not only front to back but also side to side. They tie directly into the rear frame rails and the factory bracing for the front subframe, and into the rockers on either side. The center cross member is designed to accept the front pinion mount for those that have our Torque Arm and it doubles as a safety loop too. The smaller sheet metal rails create a protected channel to run your fuel lines and brakes safely forward. Check out more info here!
-Ben, Creative Director
Old 07-07-2016, 09:34 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
Just curious would it be possible to attach the transmission mount to this as well?
Old 07-07-2016, 10:54 AM
CURVES's Avatar
CURVES CURVES is offline
Any plans to develop this for the second gen?
SCOTT
71 Camaro project. "Mulletmobile"
66 el camino "Pye Wagon"
69 Camaro. sold
Old 07-07-2016, 02:03 PM
@ Mike- The frame connectors are from the rear area of the frame back to the rear frame rails. the transmission mount is forward of them so no that wouldn't work out.
@Scott- 68-74 Nova and 2nd gen Camaro are on the R&D lineup. We don't have dates yet but we're working on it.
