Old 06-23-2016, 08:35 AM
paulk68 paulk68 is offline
Default Installing Ridetech gas cap
Hey, quick question. When installing the ridetech gas cap and filler neck do you need to drill all 8 new holes or are you supposed to use any of the 4 already in the panel. Also any one know what size bit you used to drill these holes? last dumb question does the gasket go on the cap side or on the filler neck side?
Paul
Old 06-23-2016, 11:51 AM
dhutton dhutton is offline
Hi Paul. My recollection is you have to drill 8 new holes. Gasket should go on cap side.
Don
Old 06-23-2016, 12:30 PM
Don
Don thank you very much. hopeing to start on that this afternoon when I get home from work!!
Old 06-24-2016, 05:34 AM
so I was messing with this last night, what is my best approach I assume center the cap in the panel and then mark and drill the holes? then adjust the filler neck on the back side to line up with the cap holes.
thanks again
Old 07-29-2016, 03:24 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
thanks again
You've got the right idea, Paul! I assume you've got it done though, it's been a while since you updated this.
Old 07-29-2016, 09:51 PM
randy randy is offline
make sure you install the gas cap cover so you have it positioned exactly how you want it. Heres mine.
Old 07-30-2016, 05:24 AM
130fe 130fe is offline
Thumbs up
Also, make sure you use anti seize for the bolts.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-30-2016, 12:29 PM
thanks for all the help guys, i was able to test fit it today
The Following User Says Thank You to paulk68 For This Useful Post:
Roscoe03 (04-16-2019)
