Old 07-06-2016, 03:57 AM
69x22's Avatar
69x22 69x22 is offline
Default Seat modifications 2nd gen mintubbed Camaro
When minitubbing a 2nd Gen. Can the rear seat be modified without removing
the upholstery?
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 07-13-2016, 08:14 AM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Probably not
TRACY WEAVER
www.recoveryroominteriors.com
Old 07-13-2016, 08:35 AM
The only source I know that shows what is necessary to make the rear set fit in a mintubbed 2nd gen is DSE's website. You may want to peruse the builds and see if you can find it. I believe I've seen it in SW's 73 TA build. The green car not the red car.
If I'm not mistaken, they section the seat frame in order to narrow it. They also flatten the floor and change the way the bottoms connect to the floor. Though, that might not be necessary.
Old 07-13-2016, 09:47 AM
cpd004's Avatar
cpd004 cpd004 is offline
Just throwing this out there: Not sure where I read it, but supposedly 4th gen rear seats fit with minimal modifications in a mini-tubbed 2nd gen. I haven't tried it. I did section mine and threw the original covers on temporarily.
1971 Firebird
2017 SS
Old 07-13-2016, 06:30 PM
69x22's Avatar
1957 Chevy 454LSX
Old 07-13-2016, 07:47 PM
glassman's Avatar
glassman glassman is offline
I (well a shop) uncovered them too cut down the spring steel. I had heard the same thing about the 4th gen seats (i believe it was a gto iirc)
Mike
