Old 07-07-2016, 10:08 AM
jlwdvm jlwdvm is offline
Default Circuit breaker for trunk-mounted battery?
I have my Optima battery mounted in the trunk of my 69 Firebird LS3 track/street car with the battery cable running up the center of the inside of the car to a master on/off switch mounted in the dash, then to a firewall pass-through terminal, and then on to the starter. I have a on/off positive terminal end mounted to the battery. I just saw in another build thread that a guy used a 200amp manual breaker mounted about 18" from the battery. It seems like this would be a good way to protect against any shorts in my long battery cable. Thoughts from the electrical gurus?
Old 07-07-2016, 09:06 PM
Yes you should do this! Always.
Old 07-08-2016, 07:08 AM
I was told about this company. I'm placing an order for a clamp with a couple extra 200 amp fuses.
http://www.autoelectricsupplies.co.u...4/category/192
Old 07-08-2016, 07:14 AM
You may also use a RE-SETTABLE circuit breaker which can be handy as well....
https://www.amazon.com/CIRCUIT-BREAK.../dp/B00JFBY2OU
Old 07-08-2016, 07:45 AM
Someone said in another thread that the circuit can actually weld together in a short situation? Maybe a fuse is more fail safe...especaily at the track?
Old 07-08-2016, 03:03 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
On my setup I use a ford starter solenoid mounted to the battery hold down. The big battery cable is only hot when cranking. Separate from that is an 8 gauge cable to a power distribution block on the firewall by the fuse panel that powers all accessories and has a 50 amp fuse at the battery.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 07-08-2016, 03:24 PM
Flash68's Avatar
Flash68 Flash68 is offline
Originally Posted by Chad-1stGen View Post
On my setup I use a ford starter solenoid ....
Benedict Arnold!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-08-2016, 04:55 PM
Benedict Arnold!
Ha! Says the guy with a Camaro that wants to be a Mustang!
Old 07-08-2016, 05:12 PM
randy randy is offline
Greg would this be the one you would recommend? After thinking about it i think having one would be a great idea. Plus this is easier than unhooking the battery for repairs.
Is there something out there that would still allow some power to maintain the vintage air settings and not reset my ecu?
Old 07-08-2016, 05:53 PM
dhutton dhutton is offline
Just connect them to the battery without passing them through the circuit breaker.
Don
