Old 07-11-2016, 05:03 PM
snappytravis's Avatar
Default A.C. vent install DSE Dash?
Just curious if there are any tricks to installing the drivers a.c. vent in a dse dash insert? I am thinking of cutting a hole the exact same size as the factory and would like to know how everyone attaches it to the back side of the dash? Thanks for the help...
Old 07-11-2016, 08:00 PM
Nine Ball Nine Ball is offline
I used an aftermarket vent from Vintage Air. Cut the hole out carefully with a Dremel tool (with the flexible want attachment) and the reinforced cutting disks. I drilled tiny holes in the corners and played connect-the-dots. Pretty easy, just take your time.
Founder, LS1Tech.com
1969 Camaro SS Convertible | 1970 Chevelle SS 454 | 2006 Viper Coupe | 2014 Viper TA | 2014 Camaro SS 1LE
Online Garage: www.fquick.com/NineBall
Old 07-11-2016, 08:22 PM
Musclerodz's Avatar
ditto
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-13-2016, 01:51 PM
Richio1's Avatar
Richio1 Richio1 is offline
What Nine Ball said
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Old 07-14-2016, 12:25 PM
Looks like the vintage air one is the way to go.. thanks for all the input guys, I will order one up!
Old 07-14-2016, 02:58 PM
will69camaro will69camaro is online now
What he said. I did a little different and added another a/c vent for driver priority cooling system...
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 07-14-2016, 09:50 PM
Nice work..
Old 07-15-2016, 04:20 AM
Originally Posted by snappytravis View Post
Nice work..
Thanks. Oh and my vents are from Restomod air. Not sure if mounting is the same as the vintage air but same principle. Drilled the corners and connected the dots to make the hole.
Texas A&M BSME 2008
1992 Corvette ZR-1
