Old 07-19-2016, 02:48 PM
Tom.A's Avatar
Tom.A Tom.A is offline
Default 1969 Chevelle LS3
Item Location (City/State):Yucaipa, Ca
Price:$30,000
Description: 1969 Chevelle
Pro touring LS3 Powered 1969 Chevelle, 517RWHP/ 497 Torque
Built and running project. You can finish with your own way….
This has been a long on/off again project. Body was removed and media blasted.
Frame was stripped and painted semi-gloss black. The only rust to speak of was along the seam off a torn vinyl top. Sitting in a field water pooled causing some rust holes (metal added)to top and damaging package tray area. The rear panel below window was cut out and replaced. The car still has both original quarter panels. There was prior body work on both quarters. The car is primer and was done by me so the pictures show some shadows that appear to be wavy but it was my spray gun issue.
New Body and Trim Parts:
Under carriage with raptor bed liner
Front fenders
SS Hood, with new chrome SS Grills
Header Panel
Front bumper valance
Front core support
T3 headlights
Grill, and chrome pieces
Headlight eye brows
Chrome bumper
Front turn signals
Metal wheel wells *Not installed
Rear Chrome bumper
Rear Chrome tail panel upper and lower pieces
Tail light lenses
Chrome taillight bezels
Trunk lock, door locks,
Windshield
Windshield Trim (3 piece)
Rear window trim
Rear window
Chrome side marker bezels
New door handles
New trunk
*What is needed on body….panel alignment and block sanding
New Interior items
Floor board tunnel is custom and raised for max space
Front and rear door panels, Black in color
Corbeau Seats (Purchased used but in good shape).
Crow 5 point harnesses with cam lock style
Roll cage constructed of .120 wall, 1-3/4” DOM built by a shop. Cage was built for max room.
The cage extends up into the bracing which was trimmed so the bar could extend high up in the roof line. I have had this car at higher than freeway speeds and there is no distortion or flex. It remains sturdy. See picture to help give you a better idea. The catch ties into the frame, extends through to the trunk and also up to the engine compartment.
OE style pads with Drive by wire pedal.
Ducth Boy's shifter
Dash pad, trimmed to fit down bars of cage
Autometer 3-3/8” Tach and speedo with 2-1/16” Fuel, oil, volt and water gauges These are mounted in a Covan Classic dash
Lokar park brake lever with Ironworks mounting pad
Car has B-Quiet style sound insulation, Ididit tilt column
*What is needed on inside: Roll cage will require better prep for paint
will need headliner. Note the cage is very tight to roof so a reproduction head liner is not going to work. I was building this car to drive and was not worried about a show piece. I am sure a good interior shop could come up with something. Car has no heater or a/c, still needs windshield wiper motor. I have old one (would need rebuild) and the old wiper arms also.
This is a two seater car only. So there is no rear seat period.
Drivetrain
LS3 Crate Long block, has L76 intake.
Speartech E67 ECM with harness, LS2 MAF,GM 02 sensors, Has Corvette accessories, Alternator was a rebuilt unit, Edelbrock 409 SS Headers
ATS Road Race pan, Remote Oil Filter with -12 Lines
Ron Davis radiator with dual Spal Fans, Flywheel Mcleod Series 100 clutch and pressure plate
Ram hydraulic throw out bearing with tilton remote res.
TKO600 5 Speed, .64 ratio
Classic Motorsports Group LSX style alum bell housing.
Inland Empire driveline, 3-1/2” Aluminum with 1350 u-joints
Currie 9” rear end with black powder coat (got a little scratch up)
31 spline axles with ½” ARP studs
Cats Ion third memder with True Trac posi.
3.50 rear gear
Torino/LB style.
Rick’s stainless steel EFI gas tank with 255 walborough in tank pump
Using Vette FPR
Suspension
Front Upper controls made by SPC Performance
Lower control arms made by SPC Performance
Front coil over conversion Ridetech single adjustable with 650# spring rate
ATS/AFX spindles with C5/C6 hubs, with ½” ARPS tuds
7/8” solid front sway bar.
All tie rods, and mving parts are new.
ATS/Lee 600 Steering box,
Rearend control arms Upper and Lower made by Currie enterprise, Johnnie Joint stle
Single adjustable rear coil overs, Ridetech
Kore 3 / C6 Front calipers
13” Baer 2 piece rotors front and back, Eradispeed
Rear calipers are Baer/Vette style Track plus style #136-4262065
Bare proportion valve
New brake lines
Wilwood Dual master cylinder, (Manual brakes)
Fikse Profil 13, 3 piece wheels
Rear wheel 18 x 11”
Rear tire 295/35/18 NT05 Nitto tires
Front wheel 18” x 9-1/2” front tire 275/40/18
I am sure I have missed some details. I have a full catalog or receipts. Anybody who has gone this far into a car knows what it cost. If you do the math not counting the hours I have you will see the value.
****Car has approx. 6,000 Miles. My china made Autometer shows lower but both Tach and speedo are not working correct
Tom
Old 07-19-2016, 02:55 PM
Tom.A's Avatar
Tom
Old 07-19-2016, 02:58 PM
Tom.A's Avatar
Video walk around 7/18/16
https://youtu.be/vBErA8AxFrU
hmmm. trouble posting youtube. More pics to follow. Photobucket keeps crashing
Tom
Old 07-19-2016, 04:05 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
NOOOOOOOOOO!!!!!!!
Hate to see this. Such a great car and SO much fun.
Curtis
Old 07-19-2016, 07:59 PM
Ron in SoCal's Avatar
GLWS Tom!
It's priced right, so should sell quick.
Ron in SoCal
69 Camaro in progress
Old 07-19-2016, 08:05 PM
Originally Posted by Tom.A View Post
Is that a mustang-stripe-unicorn sighting in the background??
Ron in SoCal
Old 07-19-2016, 10:45 PM
Tom.A's Avatar
NOOOOOOOOOO!!!!!!!
Thanks Curtis!
Originally Posted by Ron in SoCal View Post
GLWS Tom!
Thanks Ron! Yes that could be Dave's car or the other guy that had one just like him.
Tom
Old 07-20-2016, 06:54 PM
Tom.A's Avatar
Sold. Full payment received today. Car ships out to Middle America next week ! Seems like a great guy and car likely to stay in our little circle
Tom
Old 07-21-2016, 09:34 AM
Spiffav8's Avatar
Lateral-g Moderator
Dang! That was fast. Must have been due to my Wife being in the For Sale photo.
Curtis
Old 07-21-2016, 06:31 PM
Flash68's Avatar
Flash68 Flash68 is offline
Dang! Congrats a on quick sale Tom. Really loved this car. I mean, come on, it's not a Camaro!
Hope all is well.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
