Old 07-20-2016, 07:25 PM
Efi69Cam Efi69Cam is offline
Default Spal fan wiring questions
Has anyone wired dual Spal fans in the series/ parallel arrangement with three relays for two speeds with both fans going at the same time?
Old 07-20-2016, 07:37 PM
jwillia2's Avatar
jwillia2 jwillia2 is offline
I just went through this
Ironworks Built 1969 Camaro AKA "HillbillyDLX"
Full DSE suspension LSA T56
Forgeline MonoBlock GA1R OPEN LUG
https://lateral-g.net/members/williams69/
Old 07-21-2016, 07:29 AM
Thanks for the diagram, its easier to decipher than the service manual.
Have you run spal fans in series? What I'm a bit concerned about is whether or not the motors are good running on 6 to 7 volts.
Old 07-24-2016, 01:40 PM
jwillia2's Avatar
i don't see any issues. also they made a variable speed controller for their fans thats doing the same thing. just reducing the voltage to slow them .
Old 03-16-2017, 09:26 AM
roger1 roger1 is offline
PWM controllers like the Spal sells don't reduce voltage to control motor speed. Pulse Width Modulation is a controlled high speed switching control that varies the amount of on/off time (pulse width) to the motor.
That said, I don't believe lowering the voltage to a brushless DC motor reduces it's life. Like has been pointed out before, GM used a series/parallel system for 2 speed operation for may years.
Old 03-16-2017, 02:15 PM
130fe 130fe is offline
Post
Does anyone have a good schematic for wiring in 2 fans (with PCM fan triggers) and a trinary switch using 3 relays?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 05-04-2017, 10:03 AM
Larry R's Avatar
Larry R Larry R is offline
This schematic is the way my two Spal fans are wired. I am using two engine mounted temperature switches of different values to operate the fans; lower temperature controls series wiring and higher temperature controls parallel wiring. I don't see why one couldn't substitute a PCM source in lieu of the two temperature switches. This system works well.
