Old 08-02-2016, 04:54 PM
cray1801 cray1801 is offline
Default NT555's or Continential ExtremeContact DW's
Been searching around for products for my `72 Buick Skylark. Currently a street/strip car that I've had lots of fun with, but... it's time for a change. I'm looking to go for a mild pro-touring conversion. I'm considering SC&C suspension package, Kore3 corvette Z51 brakes, Forgeline wheels and good performance tires in the sizes I want.
Front: 18" x 8.5" with 5" BS, looking for 255/45-18
Rear: 18" x 10" with 5.5" BS and 285/40-18 since I cant find any 285/45-18's
I've narrowed it down to Nitto NT555 and ExtremeContact DW's. I like PSS but they do not offer these sizes.
I want a car that makes me confident in the curves and stops much better than current power drum brakes can provide. I may do a track event but nothing serious, almost all street driving in nice weather. Car has plenty of power and has run 10.7's on drag radials. I know I'll be sacrificing significantly at the strip but an ok trade-off for new purpose.
Are there other tires to consider?
First Post...Thanks!
Craig
Old 08-03-2016, 10:27 AM
BMR Sales's Avatar
I like the Conti's - I've got them on two cars
Old 08-03-2016, 06:35 PM
Thanks T.C.
Option 2 - same 18x8.5 wheel front and 19x10 rear.
Then I could run PSS. 245/45-18 front and 285/40-19.
Less width up front but 245 tire maybe better controlled than 255 with 8.5" wide rim.
Rear will be good width and diameter. Just don't want side wall height to be less than front.
Old 08-05-2016, 07:13 AM
Gscherer78ta's Avatar
Gscherer78ta Gscherer78ta is offline
I ran the 555's for two season of autocross and I liked them. I was able to keep up with a lot of cars that had 200tw tires and I liked the grip they provided and they seemed to last well for what I was dong to them.
Greg
'78 Trans Am - Y88-R LS3/T56,
Holley EFI, UMI Performance
Old 08-09-2016, 09:56 AM
Ben@SpeedTech's Avatar
I run 555s on my G body Cutlass and drive it daily. I Auto crossed them for a couple years but now have Falkens I swap out for that. For a street and occasional auotX I like the 555s as they perform pretty decent in all situations. The first set were worn out in a year with only a couple race events on them. But I drove fairly aggressively on the street, lots of curvy roads on the way to work. The second set I babied and they had only a little wear after about 6 months. While my car is down for a motor swap my teenage son borrowed my wheels and tires for his Cutlass. They were near bald in 3 months of his style of street driving. That should give you an idea on driving style and wear longevity. The tires handle well and are plenty responsive and comfortable on the street. Only thing I don't like is they get a little slippery in the rain, but I am lucky to live in the southwest desert and don't see too much of that.
While you're shopping around check out Speedtech's suspension packages too. I had a similar suspension as you mentioned as my first "get my feet wet" set up and eventually felt like it was limited. As I've gotten more serious about improving handling (much like going fast down the 1/4, it's hard not to want more once you get a feel for it) I've switched to a full Speedtech package on my Cutlass and the car now handles at a higher level. Speedtech suspension is simply straight forward, void of gimmicks, high quality parts that work; and are a great price for the level of quality you get. All parts are backed by a support group of folks that are heavily involved in building, driving and racing these cars and are ready to help you get your car set up.
Another cool thing you might like about the Speedtech suspension is the rear sway bar is adjustable. If you go with the rear coilover conversion like I did you can properly dial in shocks and you have 3 options for lower rear control arm mounting position to tune your launch. In less than an hour you can take a car set up for cornering and set it up to go drag racing too. Coming from a drag race background I still enjoy hitting a test and tune night now and again and these options for tuning are nice to have.
Take a peek HERE to see if these parts fit your needs.
Good luck with the build, you'll really enjoy being able to turn and stop as well as go straight fast!
-Ben, Creative Director
Old 08-10-2016, 01:44 PM
Great inputs Ben, thanks. Yes I'm also looking at Speedtech as well. Lots of options and decisions to make...learning as I go.
Old 08-10-2016, 03:19 PM
You bet, that's what we're all here for.
BTW, I didn't mention that the Falken 615s stuck at the autocross a lot better, a big improvement accelerating out of corners. not sure that applies to your situation but in my experience you can have plenty of fun with a 555.
