Old 08-14-2016, 06:55 PM
Ripped's Avatar
Ripped Ripped is offline
Default Custom length AC compressor hoses
With the changes to my engine the aftermarket hose kit that I used is not quite long enough.
Does anyone have any suggestions on where to order custom length hoses
Old 08-14-2016, 08:30 PM
gray86hatch gray86hatch is offline
You can buy all the parts in pieces and have them crimped local. I have done this on the last two cars and works great
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
Old 10-16-2016, 10:40 AM
408sbfmustang 408sbfmustang is offline
Here is the hose crimper you would need
http://www.tooltopia.com/mastercool-...FUKXfgodQdcBjw
All the hoses and fitting you can get from Summit Racing
Old 10-16-2016, 02:34 PM
If your using standard hose I have a new set Of vintage air hoses that I would sell cheap
I would add that the ez clip hose is flipping awesome to use if you go that route
Old 10-16-2016, 11:56 PM
Ghiaguy's Avatar
Ghiaguy Ghiaguy is offline
Just get the length you need and go to any Hoseman or custom Hydraulic hose place around you (take your old hose too to match up the ends) -- If there is any equipment around, there will be a place making hoses.... google is your friend..........
