Go Back   Lateral-g Forums > Technical Discussions > How To's, Tips, and Tricks
Old 08-17-2016, 06:48 PM
Ghiaguy's Avatar
Ghiaguy Ghiaguy is offline
Default What is everybody doing to check piston/valve clearance
Was looking for my old stash of clay and finally found it all dried up and worthless...... Is there a newer, tricker way to check clearance????
If not where do I find a replacement quantity of clay, and what type of clay are you using?????
Enquiring minds want to know,,,,,, LMAO
Old 08-17-2016, 07:43 PM
Che70velle's Avatar
I use modeling clay. Lightly spray your piston top, and the bottom of the valve with wd-40 or use a very light oil. This prevents sticking and staining.
I've heard people use "play-do" as well, but I've never tried it.
I've seen people use solder, but it only shows you the dimension in a tiny spot, and I like to see my dimensions across the valve face.
As far as a newer, tricker way, there probably is, but clearance is clearance, Clarence!
Thanks Dad!!
Old 10-27-2016, 06:30 PM
Neil B Neil B is offline
I use a degree wheel and a dial indicator on the valve tip with a checking spring installed. I check in 5 degree increments from 10 degrees BTDC to 10 degrees ATDC.
Old 11-19-2016, 01:04 PM
qtrracer's Avatar
qtrracer qtrracer is offline
x2. I have a used head gasket for the procedure. I find this method lots easier and more accurate than the clay method.
