Old 09-10-2016, 07:58 AM
uppster uppster is offline
Default LS3 mass airflow sensor placement
For those using the Spectre air intake tube are you cutting the tube and inserting the LS3 sensor. I have read it needs to be 10" away from the intake. It is in a 1969 Chevelle.
Old 09-10-2016, 02:32 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
A friend that builds ls motors for me always says put it in at least a 6" straight piece of tubing at least 10" from throttle body.
Old 09-10-2016, 08:08 PM
Thanks, yes I knew that, but are builders cutting the 4" pipe in half to mounting it there? Speartech sent MAF sensor #15904068.
Old 09-12-2016, 12:04 PM
cjsgarage cjsgarage is offline
LS3 should have a mounting boss and blade style MAF, in my experience. I've put in those crate engine ones from GM and they come with this style mounting boss.
https://www.summitracing.com/parts/nal-19166574
instructions are on page 2 in the bottom left for installing the boss:
http://www.chevrolet.com/content/dam...except-lc9.pdf
and the boss is directional.. that's important to note!
I like wiring. No joke.
Old 09-12-2016, 12:06 PM
The MAF you had a part number of is generally used for the GEN IV engines.. LS1/LS6 and trucks up to 06 (and 07 Classic)..
