Old 09-17-2016, 07:19 AM
732ndgen 732ndgen is offline
Default mini tubs
I know that D/S has a great mini tub set up but was wondering if their is a better option. Like a bone head I purchased a set of rim and tires on here from a guy that wasn't well known and the ccw rims ended up being 13" wide with 345 tires. just trying to make them work. any suggestions
Old 09-17-2016, 11:34 AM
transam's Avatar
transam transam is offline
If you don't want to minitub/narrow your diff you can always just rebarrel/lip your current wheels . You can order the barrels at about 200 a piece and you need 4 , two inners and two outers. Or you can contact ccw and they can do it for you.
Old 09-18-2016, 07:24 AM
Default ccws
the ccw rims are monoblock,
Old 09-18-2016, 10:40 AM
alex n alex n is offline
I was in the same boat as you , I actually put in the DS tubs and then decided I wanted a 345 so I cut the tubs out and made my own, however you can cut the tubs if you haven't installed them yet and add an 1 1/2 of sheetmetal, If you search 345's on 2nd gen camaro on nastyz, you can see pics of a car that someone did that to.
Old 09-23-2016, 03:42 PM
Default tubs
thanks for your reply.
