Old 09-19-2016, 11:13 AM
UMI Performance UMI Performance is offline
Thumbs up UMI Releases New Product: Bumpsteer kit for the GM 64-72 A-Body and 78-88 G-Body
Bumpsteer kit for the 1964-1972 GM A-Body and 1978-1988 GM G-Body
P/N 3060, 4060, 4061
Priced at $179.99/kit
UMI Performance, Inc. is pleased to announce the availability of our race tested bump steer kits for GM A-body and G-body cars. These direct bolt-in kits allow the builder to relocate the outer tie rod end lower than stock (or higher if necessary) which can help reduce or eliminate toe change during suspension travel (aka bump steer). The stud taper is exact factory fit for each application and is constructed of 4140 CrMo for strength and durability. The adjuster is 6061 for lightweight strength and features a hard anodized finish for years of durability. Kits include shims of 0.125”, 0.1875” and 0.250”. These race-tested bump steer kits are 100% designed and manufactured with pride in Philipsburg, PA – USA.
