Old 09-25-2016, 02:16 PM
J-440's Avatar
J-440 J-440 is offline
Default Adjusting camber
Evening all. I have a Magnumforce fully adjustable front suspension. To adjust camber, do I thread in/out the rod ends on my upper a-arms? Recently lowered the front end and the tires have quite a bit negative camber. Thanks again.
68 Charger, 440SC, EFI, 6-speed
Old 09-25-2016, 03:07 PM
68Cuda 68Cuda is offline
Yes, adjusting both sides of the A-arm longer, equally, should move camber positive. Adjusting front or rear will move camber and caster both. Making the front longer will increase caster and camber both.
Michael
Plano, TX
1968 Barracuda Notchback
Body & Paint:
http://www.forabodiesonly.com/mopar/...dy-2014.10252/
Engine:
http://www.forabodiesonly.com/mopar/...ictures.10230/
Old 09-25-2016, 03:10 PM
This style has fixed mounting at the frame without eccentric bolts on top, correct? Do the instructions have guidelines on how much you can adjust? You want to maintain some minimum thread engagement.
Michael
Plano, TX
Body & Paint:
Engine:
Old 09-25-2016, 06:30 PM
J-440's Avatar
Yeah I'm only 3 threads showing. I think those rod ends have about an 1 1/2" thread. Thanks again guys.
