Old 09-26-2016, 01:41 AM
funkyflynz funkyflynz is offline
Default Wilwood spindles - longer steering arms
Hi, Im converting my A body mopar to rack and pinion front steer using the RMS front end, however I'm using the wildwood spindles instead of the RMS ones for certification reason (RMS has welded steering arms and we are not allowed to weld steering arms here in new zealand). The problem is the wilwood steering arms to too short, i need to longer reach out to the tie rod end. about 40-50mm.
Does anyone know of any aftermarket steering arms that will fit wilwood spindles?
Lee
