Old 10-23-2016, 06:34 AM
paulk68 paulk68 is offline
Default 9" housing recomendation with Ridetech 4 link
Hey guys, this will be going in a 68 camaro, is there a particular 9" housing that works best with the ridetech bolt in 4 link? IO remember reading someone had a problem with the filler cap hitting.
Old 10-23-2016, 05:53 PM
130fe 130fe is offline
Post
I am using the Currie one (their first gen stock width one). No issues with it. I would recommend getting a drain and fill plug welded in (by the manufacturer or someone you hire). I would not order one from anyone with the upper tabs already welded in using a "jig". Had a local buddy just go through a two month ordeal buying one, shipped it back and forth twice because the upper tab location was incorrect (both times). After that ordeal, he returned it and started all over.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 10-24-2016, 08:32 PM
Musclerodz's Avatar
I just ordered and installed a moser 9" i ordered complete without any brackets installed. no filler neck. everything cleared no issues
Mike Redpath
Musclerodz & Customz
facebook page
Old 10-30-2016, 01:14 PM
I have a Chris Alston built br Mike it's a nice unit, but Moser and Currie can set you up with a complete set up and are great parts.
