Old 10-30-2016, 01:26 PM
Default Hose heat shielding
I have two -6 AN hoses for my transmision cooling lines they run within 2" of the headers. I'm going to run both lines in a-12 fire sleeve UNLESS someone knows putting both of them in the same sleeve will affect the cooling effectiveness. It will only be where the lines are closest to the heat source, maybe 2'
Old 10-30-2016, 06:35 PM
Which material are you using ? I was looking at the high temp silicone type for my fuel line with same issue ... that said since the pressure side is out of the cooler I would separate just for my own sanity although I dont hink heat transfer would be a real problem
Old 11-10-2016, 08:43 AM
gnx7's Avatar
gnx7 gnx7 is offline
Don't buy the cheap Summit silver heat sleeve. I used it and it was next to a header (3-4" away) and the silver foil literally fell off after a couple hundred miles.
Get something quality like DEI or similar.
Old 11-10-2016, 09:11 AM
ADY's Avatar
ADY ADY is offline
I've seen positive feedback on the DEI fire sleeve:
https://www.amazon.com/010474-I-D-Fi...6F3BYP4WS9D5FK
-Adam
1968 Camaro SS
Old 11-10-2016, 09:34 AM
Thanks The shielding I'm using is from XRP along with the hose and fittings. I may try to make a reflective shield if I have enough room.
