Old 11-03-2016, 04:13 PM
Craig69 Craig69 is offline
Default efi intake for 572
putting a 572 in a 69 Camaro and was wondering if anyone knew an intake that would fit under hood. It will be procharged so would like to have throttle body on front.
Old 11-03-2016, 07:32 PM
p51mus p51mus is offline
Default 572
would be nice if a whipple type supercharger could be made for a big block chevy.
gb69z
Old 11-03-2016, 07:50 PM
There aren't that many options available for front facing throttle body type setups for BBC. A local guy has the Edelbrock Pro-Flo setup on a TT BBC Chevelle but I think it'd be questionable fit under the hood of a F-body. It seems just tall enough that near the front where the throttle body is I think it may be an issue. Edelbrock has decent measurements available on their site for most intakes so that may be worth a look. Same intake they use on their Musi co-branded crate BBC engines with EFI option.
Your best bet is probably a Precision Metalcraft (site sponsor) or Hogan fabricated sheetmetal intake if you can swing it. Those are basically custom and I've seen some with fairly short runners which would help keep the height to a minimum.
Then if money is no object there's always the option of a billet piece like those available from NRE, Steve Morris, et al.
John
'71 Nova (Build thread)
FFR Roadster
Old 11-03-2016, 07:53 PM
Can't say I remember seeing this setup in a car but I'm pretty sure the units are available to do this. You see them in boats.
John
FFR Roadster
Old 11-04-2016, 10:02 AM
Thanks I will keep looking. May have to use one with throttle body on top. Just really didn't want to.
Old 11-04-2016, 02:15 PM
NOPANTS68 NOPANTS68 is offline
You can have one made by CFE, Moran, Hogan's etc etc out of sheetmetal. They can put the throttle body wherever you want it and make it actually work. Use that with a Holley Dominator EFI and you're set. Expect to be in it $5-$6k with the EFI in place.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 11-05-2016, 06:39 AM
Yes I was going with Holley dominator so I would have transmission controller also.
Old 11-05-2016, 07:15 AM
bretcopsey bretcopsey is offline
Not sure whether Arizona Speed's setup would work?
http://www.azspeed-marine.com/fuelinjection.html
Old 11-05-2016, 02:14 PM
No I actually have that one on the motor now and it is about 3 inches to tall. Worked well in the boat but to tall for car. Thanks
Old 11-09-2016, 06:03 AM
l2azorback l2azorback is offline
I'm running the Holley MPI set-up for a BBC on my Shafiroff 540 Ultra Street and am normally aspirated. A power adder will not work with this set-up with out increasing the size of the cowl hood. I have a factory cowl hood and can barely fit my air cleaner.
