Old 11-09-2016, 01:21 PM
Doug1's Avatar
Doug1 Doug1 is offline
Default PTFB G-braces and hood hinges
I'm trying to find a set of billet hood hinges that will fit with PTFB adjustable G-Braces. Dave tells me that most won't fit because of the hydraulic spring sticking out.
Anyone know of a set that isn't all that much wider than a factory set?
You can see from the picture below how close it would be.
Old 12-26-2016, 10:38 PM
jonathonar89 jonathonar89 is offline
Ever get around to figuring this out Doug1? I know you've asked about this on a few different forums.
BTW, the PTFB suspension looks awesome. I can't wait for my PTFB coil-over conversion to be finally installed as well.
Old 01-11-2017, 09:14 AM
Doug1's Avatar
They will not work. I might try to modify the mount that connects at the hinge base. They are aluminum so I might figure out how to land them lower.
