Old 11-17-2016, 01:03 PM
AB69Z AB69Z is offline
Default Ls coil relocation mounts
looking to move them off the valve covers to the intake area. I think the valve covers also need to be changed for the mounts?
Any suggestions on a good quality manufacturer?
Old 11-17-2016, 03:36 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Good: https://www.summitracing.com/parts/pro-69520
Great: http://store.katechengines.com/coil-...n-kit-p13.aspx
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 11-19-2016, 04:04 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default Katech
From what I understand you have to use the Katech valve covers to use their beautiful relocation brackets ?
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 11-20-2016, 12:26 PM
rallystyle rallystyle is offline
sheck44 they are designed for there valve covers but i a seen on other sites where people have drilled and tapped there valve covers then bolted on the katech brackets.
1970 El camino
1969 camaro
1996 civic
Old 11-23-2016, 01:03 AM
Nativefx Nativefx is offline
Anyone have a picture of the Katech brackets and coils installed?
Old 11-23-2016, 07:21 PM
randy randy is offline
I made my own boxes and moved them to the subframe. $100 set of wires
$100 coil extension harness
$30 in metal and bolts
Old 11-24-2016, 04:26 PM
Air-bender Air-bender is offline
Check out the 67 Camaro build on here by Dutchboys! Katech valve covers and Katech coil mounts.
Old 11-25-2016, 09:29 AM
gerno's Avatar
gerno gerno is offline
Carbuff is running the Kartech valve covers and coil mounts. I assume he has pics in the TOW build thread or you can PM him for some.
Old 11-25-2016, 05:23 PM
carbuff's Avatar
carbuff carbuff is offline
Here are a couple:
