Old 11-19-2016, 03:09 PM
lsuguy's Avatar
lsuguy lsuguy is offline
Default Fuel Line Routing and Clamps
I am getting ready to route a custom 3/8" hard line on my 69 Camaro. I plan to run hardline within a couple feet of the fuel tank and fuel rail on my LS3.
How are you guys securing the fuel line to the floorpan of the car? I plan to use either billet line clamps or cushioned clamps but I am concerned about drilling holes into the floorpan. Maybe its a non-issue but just wanted to know what everyone was doing. Any pictures or advice would be greatly appreciated.
Old 11-19-2016, 03:42 PM
DT69Cam DT69Cam is offline
I will be using the stock 3/8 line in SS. I cut both the front and rear of the line off and installed Swagelok fittings. Stock line=stock clips.
69 Camaro Convertible (LS3/TKO in the works)
Old 11-20-2016, 05:19 AM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
I use "Adel" clamps to secure my fuel lines.
Old 11-20-2016, 10:58 AM
randy randy is offline
i used stock fuel line clips since i used stock metal lines. Now underneath the car and on the area right before i would then run a flex line i used billet specialties fuel line clips.
Old 11-21-2016, 05:45 PM
lsuguy's Avatar
Thanks for the feedback guys
Old 11-22-2016, 08:28 AM
I used the Swagelok fittings on mine too.
Old 11-27-2016, 04:14 PM
Efi69Cam Efi69Cam is offline
Those of you who use swageloks, did you tighten them per the instructions? I have not installed mine yet since the specs are for a thicker wall tubing than what the SS fuel lines are.
Old 11-27-2016, 06:24 PM
I went 1 Full turn + a 1/4.
