Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 11-28-2016, 07:23 PM
jason jason is offline
Default WTB 68 Camaro clutch/break pedal assembly
Switching from an auto to six speed. Looking for a clutch and break pedal assembly with bracket for a 68 Camaro . If u have or know of one for sale, please let me know. Thank
Old 11-28-2016, 08:05 PM
Tinker's Avatar
Tinker Tinker is offline
Pm sent
Chris
Old 11-28-2016, 08:13 PM
Tinker's Avatar
Mine are 1969. They look to be different. There is currently a 67-68 set on ebay for $180
Chris
Old 11-28-2016, 08:35 PM
What are the differences from the 67-68 to the 69?
Old 11-29-2016, 03:25 PM
Z06vette's Avatar
Z06vette Z06vette is offline
The bracket is different from 67/68 to 69. I'm 99% sure you can just change the pedals without changing the bracket. I just did a brake swap on a 68, and I removed the manual pedals for an auto pedal. Just remove the clip & slide pin out. The manual pedals go in from the left side, so you may need to make a little room on that side of the bracket depending on how things are routed under your dash.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 11-30-2016, 09:59 AM
Chevy Kid Chevy Kid is offline
The brackets are different, as are the pedals. Actually, only the brake pedal is different. The brake pedal stop on the bracket is in a different spot.All will interchange, the difference would be where the brake pedal returns. If mixed, the brake pedal would not return "even" with the clutch pedal.
I just went through this on my 67, and ended up with 3 sets of pedals and 2 brackets to discover all this. What's crazy is I had mixed pedals and bracket on the car for nearly 30 years!
Tim
Old 11-30-2016, 12:12 PM
B Schein's Avatar
B Schein B Schein is offline
I am pretty sure I have what you want let me look in my Attic tonight.
Brian
Old 11-30-2016, 03:24 PM
ADY's Avatar
ADY ADY is offline
This is what I used to convert my stock auto to a manual:
https://www.summitracing.com/parts/o...t/model/camaro
The stock bracket was used as well.
-Adam
1968 Camaro SS
Old 11-30-2016, 08:17 PM
Thanks very much guys for the info. Going to try a pedal set and reuse the stock , automatic , bracket . I would defiantly be interested in an OEM set if someone does have a set to sell. I'm trying to gather up everything I need before I tear it apart. Also ordering a t56 magnum with conversion kit. Seems to come with everything less the pedals .
