Old 07-27-2006, 11:20 PM
4mm 4mm is offline
Default Auto or Manual Trans for FI LS2?
I am in the process of securing a low compression all forged LS2 that will be receiving a blower. The engine should have around 720-800hp at the crank and will be going into a Chevelle. With that kind of power output, I would tend to believe an auto trans would be best and more fun. What do you guys think? Auto or manual? Would I be limited to a 4L80e with that kind of power? The only drawback I see is the power it needs to get going. Let me know your thoughts..
Old 07-28-2006, 08:42 AM
camcojb camcojb is offline
Frank,
they'd both work. The auto would probably be easier to hook and stay hooked up on the street. I had a 4L65E behind that combo that worked awesome, so they have made strides in making them live. The 4L80E is obviously even stronger. That and Steve's Shrifter makes a really fun driver.
A TKO/T56 would also handle the power fine, although I'd recommend the upgraded shift forks/output/sliders on the T56. Also need a good clutch. Just depends on what you want really.
