Old 07-28-2006, 04:43 AM
jwillia2's Avatar
jwillia2 jwillia2 is offline
Default cam/vaccum issues
guys,
i am in the process of building my 427, and I am trying to select a cam. I am changing from the stock solid lift cam to hydraulic, and would like to get the baddast cam possible without vaccum issues. i am running the new DSE RS headlight kit, so i am not worried about the headlight doors, just my brakes (baer track). how big of a cam (lift/durration/lobe sep) can i run without creating problems with my booster???
thanks
justin
Ironworks Built 1969 Camaro AKA "HillbillyDLX"
Full DSE suspension LSA T56
Forgeline MonoBlock GA1R OPEN LUG
https://lateral-g.net/members/williams69/
Old 08-03-2006, 06:18 PM
kilrcam kilrcam is offline
Originally Posted by jwillia2
guys,
thanks
justin
If you don't have the cam yet call a cam grinder. Tell them what they need to know and they will tell you what you need. I just had a custom solid roller cam ground for me for my set up. If you have one ground for your setup it will be matched and you won't be disappointed. And the cost is not really much more than buying some off the shelf piece that may work ok but not great.
Brad
91 camaro RS, 70 chevelle, 99 dodge dakota,
62 thunderbird, and 89 cougar
No Sympathy Racing
No sympathy for the loser
http://img.photobucket.com/albums/v6...marodakota.jpg http://img.photobucket.com/albums/v6...o/DSC00314.jpg
Old 08-03-2006, 09:13 PM
Musclerodz's Avatar
guys,
thanks
justin
Buy a hydroboost setup from Hydartech and eliminate the issue all together and get better brakes. Win win.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-04-2006, 08:55 AM
jwillia2's Avatar
thanks for the input!!!
