Old 12-14-2016, 08:00 PM
AB69Z AB69Z is offline
Default Cruise Control With Manual Transmission
I would like to have this on my 69 Camaro. Anyone done this?
Old 12-14-2016, 09:22 PM
Dakota digital?
Old 12-15-2016, 06:10 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
What powertrain are you running? Newer LS all you need to do is add a switch.
Old 12-15-2016, 09:09 AM
samckitt's Avatar
samckitt samckitt is offline
Newer LS? Please elaborate.
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-15-2016, 10:46 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
I'm looking for info as this is something I would like to do in the near future. I have an L76 w/E38 ECM and a T56.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
Old 12-15-2016, 02:56 PM
modernbeat's Avatar
modernbeat modernbeat is offline
It's not hard. Typically the only difference between a manual and auto cruise control is an additional momentary switch on the clutch pedal in parallel to the switch on the brake pedal.
Jason McDaniel - Vorshlag R&D
Old 12-15-2016, 03:38 PM
130fe 130fe is offline
Post
I have this kit, plan on installing this winter.
http://www.dakotadigital.com/index.c...od/prd1004.htm
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 12-15-2016, 05:23 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I have the same kit that Chris posted in the link above. I drove from FL to NJ this past September, couldn't have made the trip without it.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 12-15-2016, 08:37 PM
I'm running an Ls3 crate motor from GM
Old 12-15-2016, 09:31 PM
CamaroAJ's Avatar
I'll look tomorrow through my info. I think it's the E40 ecm that you can do it on.
