Old 12-19-2016, 10:18 AM
DT69Cam DT69Cam is offline
Default Raptor liner/Dynamat
Anyone spray Raptor liner on the interior floor and then cover it with Dynamat or the like ?? I was just wondering if the Dynamat would stick ?? Also do you think the Dynamat will hold moisture ??? Thx
69 Camaro Convertible (LS3/TKO in the works)
Old 12-19-2016, 10:27 AM
cpd004's Avatar
cpd004 cpd004 is offline
Dynamat sticks to everything it seems like. I don't see an issue with it sticking to raptor liner at all.
1971 Firebird
2017 SS
Old 12-19-2016, 10:31 AM
Thank you!
Old 12-19-2016, 03:36 PM
66fury's Avatar
66fury 66fury is offline
I've done it and it works
mark
Old 12-19-2016, 03:55 PM
Old 12-19-2016, 05:38 PM
Anyone put it over lizard skin? It's much more the textureed than raptor
Old 12-19-2016, 06:05 PM
SkeWest SkeWest is offline
I did and had no issues. I did have an issue with the lizard skin not adhering to the factory seam sealer on areas of the floor, but the dynamat stuck to everything.
Old 12-19-2016, 07:27 PM
gnx7's Avatar
gnx7 gnx7 is offline
I sprayed the Lizard Skin (sound and heat barrier) on the floors/trunk of my Chevelle and it turned out nice! I didn't prep it well and used an acid etching style primer on top of the prepped metal. I may still put something on top of that for additional barrier....
On 2 of my work trucks (Tundra) that get tools put back there and I would say not very abusive on it.... the Raptor liner was sprayed on there. Followed the instructions to the letter.... and bought all their products.... even let it sit an extra week after spraying to be extra cautious.... the product is not very tough as claimed. The coating chipped very easily and simply didn't have any real thickness to it. It didn't seem to adhere well to the fully prepped surface that I spend hours trying to make right. Rhino Liner in that instance is a much better product. I would never recommend Raptor liner to anyone that wants to use it as a bed liner.
Old 12-20-2016, 04:03 AM
130fe 130fe is offline
Post
I am thinking about going this direction http://Sounddeadenershowdown.com this winter. I rode in a car that had this done and it was very quiet.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
