Old 12-22-2016, 10:31 AM
jimmythehand jimmythehand is offline
Default timing of paint and body
I am looking for some advice on when i should send my 68 camaro for paint and body(most metal work has already been done with nearly all new sheetmetal). Since i was starting with a rolling shell, my original thought was to basically build it to make sure everything fits correctly and then tear it all down for paint and body and then rebuild. Currently I have installed the front/rearend and engine/trans without problem. Should i continue to install the other components or am i just wasting my time by building it twice? thanks.
Old 12-22-2016, 11:30 AM
jy211's Avatar
jy211 jy211 is offline
build twice, at least
Old 12-22-2016, 12:26 PM
dhutton dhutton is offline
Driver or high end car? How much more "custom" work to do?
Don
Old 12-22-2016, 12:39 PM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
...and make sure it goes to the shop with with any and all exterior trim and door and trunk rubbers/bumpers. The latter is critical to set the panel alignment.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
Old 12-22-2016, 01:29 PM
Build EVERYTHING that is going on the car.... brake lines - fuel lines - wiring "runs" (holes or bulkhead fittings etc) not the actual wiring.... but where it's going thru the firewall... etc. How do you intend to hold the wiring.... will that need attachment points etc.
In other words -- what will you scratch or mess up doing it AFTER paint?
The beauty of raw is that - you decide something needs to move over 2" to the right and the hole is in the "stock" location..... Raw I can patch the stock hole -- and I don't mind using power tools to punch new holes etc in raw form.... Once that bad boy has paint and panel's aligned -- yeah! You're not going to want to move ANYTHING or punch a hole in anything.
So the right answer is ---- WHEN YOU'RE POSITIVE THERE IS NO MORE FABRICATION to be performed.... then it's ready for body and paint.
Old 12-22-2016, 06:27 PM
Musclerodz's Avatar
put as much of it together as possible before paint and body. That way there are no surprises after paint.
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-23-2016, 12:36 PM
thanks for the input.
