Old 12-23-2016, 10:50 AM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Default **NEW** - USA Designed Aluminum Radiators - Direct-Fit
We have just Signed with Cold Case!
Some Quick Facts:
USA Designed, Modified and Tested
100% TIG WELDED direct-fit
Radiators for many applications for GM, Ford and Mopar
LIFETIME WARRANTY
60 Day "Cool Guarantee"
1.25" Tubes - Severe Duty Rated as Standard
Polished Tanks standard
Accepts Factory Shroud
Filler Neck Welded from Inside
Most Radiators RETAIL at $369 or less, Auto or Manual!
Some LS swap applications are out with more on the way. They will have Inlet/Outlet on the Pass. side and no steam tube port. These are also $369 List!
Here is some info on the company that they posted..
Q- Is Cold Case a new company?
A- While the Cold Case brand is only a couple of years old, Cold Case is a product line of Max Performance Inc. which has been in business as a specialty American car and truck parts supplier for the past 30 years and was started by the same people who brought you Pypes Performance Exhaust.
Q- there's a lot of debate over Copper/Brass or Aluminum.
A- And there probably always will be. If you are doing a concours correct numbers matching vehicle, you simply need an original copper/brass OEM radiator. However, Aluminum, although much lighter, is incredibly strong when no epoxy is used. It dissipates heat faster. It looks nicer. Aluminum pricing is down and copper pricing is up. It's a change for the better for most of you! As you read further, you'll see we've answered any other negatives with regard to aluminum.
Q- The market is full of Radiator Companies. Why yet another?!
A- Yes, agreed. We fully admit there is no shortage of expensive high quality radiators and there is no shortage of no-name aluminum radiators on all over Ebay and Amazon but we feel there is a big need for a high quality brand you can trust at a price that is not all that far off of the cheap no-name brands.
Q- Do you have radiators for everything? Do you do custom work?
A- At this time, we don't do custom work. We only make radiators that we have identified as at least somewhat popular. Everything we have is made in a production environment in reasonable quantities. This allows us to keep our prices down,
Q- So what makes Cold Case better than the high end brands
A- We're not claiming to be better than these brands. In fact, one of the disadvantages of Cold Case is that we don't do custom work and we don't do specialty high horsepower vehicles at this time. However, our construction quality, design elements, tig welding and materials all rival the big guys. One thing we can claim that beats some of the expensive box welded tank lines is that our radiators are designed to fit in the factory position with factory hardware, shrouds and brackets in most cases. We can claim this because both our top and bottom tanks are stamped to look and fit like originals.
Q- What makes Cold Case better than the all the no name brands?
A-
1. We have stamped tanks for an OEM look and application correct fitment
2. Rather than using 2,3 or 4 small tubes in our cores, All our radiators are built with BB capacity utilizing 2 oversize rows that cool 20,30 or even 40% better than 4, 3 or 2 row cores the no name brands use.
3. All our tanks are fully polished
4. We use OEM petcock valves
5. Our filler necks are welded from the inside instead of the outside.
6. Our filler necks allow you to use an OEM radiator cap if you choose.
7. Because we use OEM style tanks, ours can mount using all the factory brackets, fan shrouds and hardware.
8. We offer a Lifetime Warranty and a 60 day cool guarantee.
9. Our tech staff is always available by phone or e-mail to answer your questions
10. Although the brand is new, our parent company has been around for 30 years. You can trust we'll be around in the future.
Q- How can you offer such a high quality product at such a reasonable price?
A- 1. We use stamped tanks which require less welding to produce
2. Our line isn't quite as expansive as others but each model we make is
made in higher production volume to reduce costs.
3. We're the new kid on the block. We have to get your attention
somehow. Maybe if we get rich and famous, we'll raise our prices
too!
Here are a few pics...
67-69 Camaro, Nova, Early Chevelle:
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 12-23-2016, 02:05 PM
MCB Matt's Avatar
FYI - Rads are USA designed, modified and tested. They are actually built off shore.. Sorry for any misinformation.
MCB
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
