Old 01-12-2017, 09:24 PM
Doug1's Avatar
Doug1 Doug1 is offline
Default Max positive camber and toe settings on 2nd Gen F-body
I had the question below posed to me regarding a 2nd Gen Trans Am by a pretty knowledgable mechanic. It is beyond my expertise. Do one of you suspension experts have any thoughts on this?
"He is running some good Nittos and 17" x 9" wheels. I was hoping that you had some thought on what if any toe adjustment would be necessary after the max possible caster adjustment was made. The old school thought is that if one wants to feel more feedback in the steering wheel, you simply install as many shims as possible to the rear of your upper A arms by the way of removing them from the front and installing them onto the rear. Of course, there are limits to how many can be placed on the rear area as you still have to have the same caster setting for both sides while maintaining the proper camber setting. I saw that I can obtain more than the factory suggested +1 caster setting by installing these offset upper A arm shafts and may start using them on all of our builds: http://www.moog-suspension-parts.com/moog-k6146 Do you have any knowledge on how this will effect the toe setting? With the max positive caster setting (+4 or more degrees) do you have any knowledge or suggestions in what the toe would be?"
Old 01-12-2017, 10:54 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
What is intended use of the car?
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 01-13-2017, 08:56 AM
BMR Sales's Avatar
If you are running Bigger Wheels & wanting more Positive Caster, I would run a good set of Tubular A-Arms. These will be built with more Positive Caster designed into them, they will be Lighter & Stronger than Stamped Steel Arms.
Old 01-13-2017, 09:36 AM
Doug1's Avatar
Street and limited Road course. He was curious about the best settings for higher speeds using stick control arms. I'm no expert but speed wouldnotse toc change the setting requirement as much as cornering other than neededing a good caster setting to help steering return to center.
Old 01-13-2017, 10:23 AM
UMI Tech's Avatar
UMI Tech UMI Tech is offline
For general street driving I'd certainly run some sort of toe-in or at the very least, straight up. The toe-out we sometimes use for track use isn't very conducive to street comfort as the cars tend to wander.
Key word being street...
ramey
Old 01-13-2017, 10:37 AM
Doug1's Avatar
Any idea what amoujnt of toe-in?
Old 01-13-2017, 12:57 PM
UMI Tech's Avatar
1/8" if 1 road course a summer.
1/16" if 5x per summer...
Old 01-13-2017, 06:12 PM
Doug1's Avatar
Thanks for the advice!
