Old 01-19-2017, 11:33 PM
Bmf5150 Bmf5150 is offline
Default Who here has a first gen camaro with the speedtech road assault suspension??
Who here has a speedtech road assault suspension with the ats spindles on a first gen camaro??how do you like it,handling and ride quality??
Old 01-20-2017, 02:49 PM
Anyone?
Old 01-24-2017, 02:31 PM
Does anyone here know if the speedtech setup fixes bump steer say as well as the ridetech tru turn??
Old 01-27-2017, 08:44 AM
Blake Foster's Avatar
On The AFX spindle the location of the steering arm as been revised to help improve the bump steer when using (ideally) the short Z28 steering arm. if you are very concerned about bump steer no matter what suspension parts you use you will need to invest in a bump steer gauge and learn how to use it. bump steer is a very finicky thing to adjust. ride height and caster setting both change bump steer. so first you have to get those figured out. then dial in the bump steer based on how you set the static Toe, so for street if you set the toe at say 1/8 total toe in then when you adjust the bump steer it needs to be adjusted so it only bumps in and does not got from in to zero and then either in or out. if you set it up for track at say 3/16 toe out then you need to adjust the bump curve only goes more OUT so to say one part The AFX spindle "Fixes" bump steer is a bit of a Vague question. Same goes with the Ridetech TruTurn
Blake Foster
www.speedtechperformance.com
Old 01-27-2017, 02:48 PM
Thanks Blake
Old 01-27-2017, 09:19 PM
https://www.youtube.com/shared?ci=__0-rDILuHU
Nice looking setup
Old 02-01-2017, 06:56 AM
jdeliveryguy jdeliveryguy is offline
What's the largest wheel and tire combo you can squeeze on the front with speedtechs system with AFX spindles. Don't mind modifying inner fender.
Old 02-01-2017, 11:14 AM
Really the inner fender does not need to be modified. the limiting factor becomes the Sway bar and the inside of the rim.
The One lap Camaro had 18 x 9 with 6.375 bs we have never put that large a wheel on
typically 8.5 with 5.5 or 8 with 5 bs and then a 255 to 275 tire these are all 18" dimensions
Blake Foster
