Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Closed Thread
Old 01-20-2017, 10:03 AM
jwcarguy jwcarguy is offline
Banned
Default WTB new or near new LS7 427 cid Block feeler?
Item Location (City/State):Las Vegas, NV
Price:1
Description:I am looking for a new or near new std bore LS7 (427 cid) engine block
I have a complete LS7 engine that had only 4 miles, yes 4 miles on it and GM tech found issue with #3 piston assembly, during initial startup
So I need a new engine block, already priced my cost at Chevy dealer, just checking to see if one was out there first
I have complete new (4 mile) LS7 rotating assembly with bearings/ rings (have new piston assembly too) forged crank, titanium connecting rods, & coated pistons
All NIB GM coated main & Rod bearings sets
CNC Ported LS7 cyl heads complete, w/ rockers/ stands, bolts
LS7 Cam, timing set, lifters & trays
All NIB GM gaskets , seals & bolts (for entire engine)
all covers (front, rear, valve covers, LS7 valley, w/ seals)
LS7 Intake manifold ,w/ NIB LS7 DBW Throttle body, GM fuel rails
LS7 Dry Sump oil pan assembly , oil pump and dry sump oil reservoir tank (Corvette)
LS7 Balancer
Ignition coil packs & brackets
pic for attention
In Las Vegas, NV 89131
Please pm/ call/ text if you have a block
(702)677-4085
Old 01-20-2017, 10:45 AM
Che70velle's Avatar
So if I understand this correctly, you purchased a new GM crate LS7, and it was hurt. Is there not a warranty from GM, that would replace the hurt block, and like components?
Would you sell the hurt block?
Thanks Dad!!
Old 01-20-2017, 10:47 AM
gnx7's Avatar
gnx7 gnx7 is offline
Another option would be to have Steve Demirjin at RED in Oceanside, CA do a resleeved 5.3 and use those billet main caps. He offers new alum 5.3 blocks for $850 to get the process started. Or have him simply machine that block which he does all the time.
He knows what he is doing.
http://www.raceenginedevelopment.com/block-gallery/
Old 01-20-2017, 10:53 AM
Banned
Scott,
I have ALL the components from the block
Believe or not, GM wanted the block destroyed (aka sledge hammer to it), so block is gone
that is why I just need a new block, I literally have a complete engine (with original and new coated bearing sets and new #3 piston/ rod assembly w/ new rings, seals gaskets & bolts)
Thanks, Jeff
Old 01-20-2017, 10:55 AM
Banned
Nice option Mark!
I was leaning towards the GM block, in case I have to sell it later?? ( you know how plans change, LOL)
Thanks, Jeff
Old 01-20-2017, 02:40 PM
Same as pro touring ....price must be included as per forum rules
Old 01-20-2017, 02:46 PM
Banned
If it's for sale you must include a price as per forum rules
Are you a moderator? If not, please leave the "policing" of the forum to them
My ad clearly states that I am looking for a block to buy, I only mentioned that I may consider selling it if plans change
Have a great day
Jeff
Old 01-20-2017, 02:55 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
This isn't Pro Touring. Jeff has followed the rules. At this point it's WTB, not a for sale. If he does cross over, Jeff will repost or update this tread. I don't see an issue.
Curtis
Old 01-29-2017, 09:47 AM
Banned
pic added
Old 01-30-2017, 10:39 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
And thank GOD that it isn't!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Closed Thread
