Old 07-31-2006, 10:49 PM
cp72ss cp72ss is offline
Default Recommend a Transmission
Hello,
I am in the process of building a 72SS Chevelle and am looking for a tranny recomendation. I'd like to stay with an Automatic as the car is currently a TH400 car. I realized after tearing into my current tranny that It might be a little more expensive but better off if i looked into a 4L80E instead of rebuilding my 400. If anyone has any suggestions on who to call or where to go please let me know.
Thank you.
Chris
Old 08-01-2006, 06:48 AM
Steve Chryssos's Avatar
Contact Bowler Transmission. http://www.bowlertransmission.com
________________
Steve Chryssos
Ridetech.com
Old 08-01-2006, 09:18 AM
nitrorocket's Avatar
Definetly search for a nice 4L80. The T400 is nice, but I wish I had the programability of a electronic trans. If it does go past the budget, a built T400 is pretty much bullet proof.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 08-03-2006, 02:32 PM
ilovefirstgens's Avatar
ilovefirstgens ilovefirstgens is offline
...and someone might have a neat paddleshift setup for it, but who???
Brian
'68 camaro
Old 08-03-2006, 07:18 PM
Default Thank you
Hey, Thank you for the suggestions. Much appreciated
Old 08-04-2006, 01:45 AM
Bandit's Avatar
Bandit Bandit is offline
Default Real cars have 3 pedals
I suggest swapping to a manual gearbox!! Unless you have to have an auto for some reason.? it is pretty simple doing the conversion if you go through a company like Keisler or Classic 5-spd. I did the entire swap in my 80 TA by myself in a few days, it was straightforward (and I am by no means a mechanic).
I had been dead-set on going with a 700r-4 (cheaper), then I changed my mind to 4L80E (stronger), but once I started pricing everything out, i.e., electronic controller, hd torque converter, etc, I realized I could convert to a Tremec TKO-600 for the same money. Now I can be in whatever gear I want, have a bulletproof tranny, and an extra gear over the OD autos.
Here's the links in case you're interested in going this route.
http://keislerauto.com/gm/chevelle-gen2-kits.html
www.classicchevy5speed.com
If you absolutely must have an auto, check out this link:
http://www.transmissioncenter.net/4L80E.htm
This is the 4L80E I was going to use, it is an absolute beast!
