Old 03-04-2017, 05:03 PM
firebob's Avatar
firebob firebob is offline
Default Rear brake pads
I'm looking for a better set of brake pads to replace the ones that came with the SSBC rear conversion kit. They said they are the same size that came on 87-88 thunderbird turbo coupe. No idea what kind came in the kit but I would like to find some with a bit more grip to keep up with the front brakes.
Anybody got any suggestions or part numbers for me? It would be greatly appreciated.
So after more research I have a choice between the Hawk HPS and the Poterfield R4S pads. I need good grip at low heat levels for street use but something that won't fade if heated up( I do track the car occasionally). I don't care much about pad wear but don't want to have to replace the rotors if I don't have to( apparently they're proprietary and I have to buy them from SSBC).
Robert
Robert
https://youtu.be/eaWBd3M9MN4
Old 03-06-2017, 06:39 PM
Hydratech®'s Avatar
Hydratech® Hydratech® is offline
Supporting Manufacturer
HydratechBraking.com
https://www.summitracing.com/parts/e...172r/overview/
Have a local machine shop machine the rotors with the finest finish possible - some of the latest brake lathes also finish up with a special hone that allows the new pads to bed in very quickly.
There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark <-- the Ukrainian - Slava Ukraini !
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 04-02-2017, 05:11 PM
Hydratech®'s Avatar
Question Progress ???
Have you had a chance to install the replacement rear brake pads yet? And if so, how is the response now?
