Old 03-07-2017, 08:50 AM
samckitt's Avatar
samckitt samckitt is offline
Default Help ID LSX acc pulley.
The 2 pulleys down by the AC compressor in this pic. It is on the Bandit TA from Year One. The pulleys look like something from Street & Performance. Looks to me like it puts the AC compressor down low but on the same belt as the main belt on the Vette acc drive.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-07-2017, 01:54 PM
kevin_l's Avatar
kevin_l kevin_l is offline
Looks like street and performance setup to me. I've called and talked to them about that setup. I dont believe its in their catalog but they will make it for you. If you can run the aux belt then, Alan grove makes a low mount, and dirty dingo just release a very close fitting bracket sd7b10.
Old 03-08-2017, 10:11 AM
samckitt's Avatar
Somewhere I read Street & Performance had closed.
I was wanting to try this to try to push the AC compressor forward as much as possible.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-08-2017, 02:14 PM
dontlifttoshift's Avatar
I can't see the picture. :shrug: Is it this one?
Donny
Old 03-09-2017, 06:22 AM
samckitt's Avatar
Shows the same content. The two aluminum pulleys down by the AC compressor is the ones in question. Pretty much decided it was from Street & Performance.
Scot
86 Monte SS
LS2/T56 Magnum
