Old 03-07-2017, 02:04 PM
Rocketw19 Rocketw19 is offline
Default 6L80 - 377 gears
I have a 62 impala with an LS3 and matching 6L80 trans hooked up to 377 gears. The car seems like it is launching in 2nd gear. I have almost 500hp and the tires will not brake loose. if I am anywhere other than taking off the car pulls very hard.
I just changed to 377s as I though my gearing was wrong so now I am thinking its something else. My tuner is going to look at the tuning of trans next week but I am impatient I want answers now, lol. I am running 22" wheels in back on 285 tires so they are tall but something is not right.
I found this forum looking for frame info (frame is next)but seen this section and lots of good reply's so decided why not give it a try maybe one of you had this happen before and its an easy fix?
thank you for your time.
Old 03-07-2017, 02:41 PM
Your tuner should be able to program in your overall wheel diameter and rear end gear, so as to make the transmission do what your car expects, rather than whatever the original program for the engine/transmission was intended to do. With HP Tuners or something similar, your tuner (or you) should be able to work this out quickly by correcting a few basic parameters, unless there is an ABS-related glitch, which may require further investigation. On a side note, with an LS3, you should still be able to burn those tires taking off in second gear; you might be in third.
Someone else here should have something more enlightening, but most on here are focused on the manually shifted side of things.
Old 03-07-2017, 03:22 PM
I m hoping and was looking for reassurance it was just the trans tuning.
we did the math and 377s seemed best but the tires don't brake loose. I can go 80mph and go WOT and it takes off like a bat outta hell but the first gear just kinda feels weird almost like it has traction control or something?
Monday the 13th I have appointment and hopefully its all fixed but until then I stress.
thank you for repling
Old 03-07-2017, 08:54 PM
dhutton dhutton is offline
I would contact Speartech. They are very good with those transmissions. You can send the trans controller to them for programming. Instructions on their website on how to remove it.
Don
Old 03-07-2017, 09:21 PM
Don
I'm going to google them now. Thank you very much
Old 03-08-2017, 02:54 PM
hifi875's Avatar
hifi875 hifi875 is offline
that sounds like a lot of gear for that tranny. most cars run low numberic gears with that tranny don't they? My father inlaw had a 6l80 with a ls9 and 3.89 gears several years ago and it was way too much. Due to lack of computer programing for a ls9/6l80 in 2010 he ended up pulling it out and going t56 magnum
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 03-08-2017, 06:05 PM
I was thinking the same thing but he said he is running 22 inch wheels so maybe it is ok?
Don
Old 03-08-2017, 10:41 PM
Don
Ya I am not gonna lie I have no clue the math but my tuner and the the shop that installed the gears both recommended 373 sorry not 377. (over all tire height is 30")
can feels great everywhere specially on the freeway its a freight train even first or taking off dont suck but it should smoke the tires at half throttle. I never dyno-ed it as the numbers are not that important to me but its got to be close to 500 at the wheels.
Monday my tuner is gonna plug it in and go over everything I hope its something silly but my luck it isn't.
Old 03-09-2017, 04:38 AM
Your tuner cannot tune the transmission without removing the controller. If you are running the stock transmission controller tune that could be your problem. Which torque converter are you running?
Don
Old 03-09-2017, 06:35 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Don
I 2nd that. I spoke to them and that's who I'm sending mine to when it's time.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
