Old 03-09-2017, 09:56 AM
DaCajun DaCajun is offline
Default All aluminum RHS Tall Deck 454 w/ Texas Speed CNCed LS7 Six Bolt Cylinder Heads!!!
Item Location (City/State): Lewisville Tx. 75077
Price: $11750.00
Description: RHS Tall Deck 454 w/ Texas Speed CNCed LS7 Six Bolt Cylinder Heads!!!
All this needs is to be finished torque plate honed to the new owners clearances per application, be it naturally aspirated, forced induction or be it nitrous. As for the static compression, with a .041 gasket it should be right around 12.4:1. But can easily be reduced with a thicker head gasket set if so desired. RHS aluminum tall deck 9.750" block with 4.120 bores. The rotating assy. has been balanced... All that is needed is to be torque plate honed and assembled....
Texas Speed 285cc PRC six bolt LS7 heads w/ titanium intake valves and stainless steel exhaust valves. These heads were purchased new from Texas Speed then sent directly over to Frankenstein Racing heads to have Chris perform his magic on then to get them flowing 410@ .700!!! The intake ports are now at 295cc's. These heads were on a ERL 434 for about 60 street miles and four dyno pulls, they were replaced with an identical set of heads just like them but with the smaller 64cc combustion chamber to bump the compression up on the 434. These heads have a 70cc combustion chamber. As you can see in the pictures they look as new. I even have the original box they came in....
Flow numbers for the heads after Chris Frank's work...
Intake
.100/70
.200/147
.300/240
.400/300
.500/353
.600/380
.650/396
.700/405
.750/410
Exhaust
.100/55
.200/120
.300/170
.400/215
.500/225
.600/233
.700/242
.750/250
And here's the specs for the springs...
.675" EHT Double Spring Kit
item# 199-675 PRCSpringKit
Install Height: 1.810"
Closed Spring Pressure: 148lbs @ 1.810"
Open Spring Pressure: 450 lb. @ .600" lift
Open Spring Pressure: 490 lb. @ .675" lift
Maximum Spring Lift: .675"
Coil Bind 1.060"
Spring Rate: 483lbs/in
Eagle 4.250" 4340 steel crank with ESP armor (nitride)coating
-crank has been balanced and has had a roll pin added for the ATI balancer hub, NO BALANCER (hub only) The balancer shell must be purchased from ATI.
Eagle H-beam 4340 steel rods 6.460" length, ARP 2000 7/16" bolts
Wiseco custom LS7 valve pocket flat top piston, -8cc's, with GFX 1.5MM, 1.5MM, 3.0MM rings, heavy wall tool steel pins, 1.165" CD
FM 152M Competition main bearing set
FM 8-7100CH Competition rod bearing set
ARP six bolt head stud set for the RHS six bolt block.
$11750.00 Shipped to anywhere in the lower 48 states!!! If you are local to the DFW area, come on by, pay cash and I can cut you a better deal since I won't have to mess with crating it up and getting it shipped out....
Oh, and absolutely NO TRADES and I WILL NOT SEPARATE ANY OF THIS STUFF. IT ALL NEEDS TO GO AS IS!!!! So please don't even ask!!!
Thanks,
Dave
Old 03-21-2017, 06:39 PM
Here's a killer big cubic inch all aluminum small block that's perfect for Protouring type car!!! Or it'll work just as well in a drag car or even a boat as far as that goes!!!
Come on guys, spend some of that tax return money on this cool engine!!!
If need be, I can crate it up really well if this needs to be shipped. And I'll take plenty of pics while doing so so you can rest assured knowing it'll make the trip just fine!!!
I need this sold so I can buy a fricken $14500.00 LS billet block!!! Wanting to make 3000hp is damn hard on one's pocketbook!!!
If you have any questions just let me know!!!
