Old 03-11-2017, 05:07 PM
Shadow1939 Shadow1939 is offline
Default Electric water pump advantages?
I am working on a 1969 Firebird convertible with a 400 and 4L80 transmission.
I'm about 330hp at the crank, pretty stock and 3.73 gears. I'm seeing a lot of builds now with electric water pumps.
At this time it runs about 185 all day long on the freeway with a flex fan and aluminum radiator, came on the car, except at the light after getting off the freeway. It will go to 210-220 in a matter of 2.5-3 minutes. I know a electric pump runs at a steady rpm, so I would have the same flow all the time. I don't plan to stay stock, but for now I miss the convertible.
A friend is all so telling me 2 electric fans would help for the same reason increased cfm's over pulley fan at idle.
Please assist in my decision, since the cars apart I want to do it right
Old 03-11-2017, 09:16 PM
Everything I've read keeps going back to a stock clutch fan and shroud. If that doesn't work, you need more radiator. With only 300-400 horse, it should work.
