Old 03-20-2017, 09:15 AM
732ndgen 732ndgen is offline
Default lt-4 install help
I'm installing a new lt-4 in a 69 Camaro, with saying that having trouble figuring out how to plumb the dry sump system and the best direction to go with radiator, air to water cooler. I was thinking of going with auto rad system or PRC makes a complete system also. As for headers ultimate headers is the only system I can find. Any help would be apreciated
Old 03-20-2017, 02:09 PM
Ns RS's Avatar
Ns RS Ns RS is offline
Had the same question as well - I've been following Chris' 69 LT4 build on FB and from his feedback no notching of the DSE frame is necessary when running ac and that the ultimate headers do work fine. It should be close to being done and it looks to be dry sumped as well.
Mark I know as well is in the process with Super Chevy mag on his 69 LT4 patina'd (gordon copied build - lol) no updates as of yet.
Per the link below, " If using the Chevrolet Performance engine
control kit, a pulse width modulation capable fuel pump that delivers 500 kPa (72psi) at 45 gallons per hour is required. If not
using the Chevrolet Performance engine control system, then a fuel pump and a regulator that delivers 500kPa (72psi) with 45
gallons per hour of flow must be used."
https://www.chevrolet.com/content/da...p-19332703.pdf
Cooling the motor is my particular worry and await other finished installs to see how they've managed the cooling component. Mark has certainly solved this problem and I look to his last few builds for reference.
Old 03-20-2017, 09:20 PM
ironworks's Avatar
We used an autorad unit, also. (OF COURSE WE ARE A DEALER )
The autorad unit is a much bigger radiator so we felt covered. The vette has airflow issues due to the aero package.
We made most everything, AC bracket to use a sander compressor and we have to make a dry sump pan adapter to get things to clear the sub frame.
Check our website we have a ton of pics.
Old 03-27-2017, 09:33 AM
Default lt-4
Thanks for the input, ill call an a price for the autorad support.
Old 03-27-2017, 10:06 AM
would you be able to replicate what you did for your front runner system for me,just checked on price of the auto rad and ill be ordering soon.
