Old 04-03-2017, 12:39 PM
Goosesdad's Avatar
Goosesdad Goosesdad is offline
Default Emergency Brake - Electric
Is anyone using the E-Stopp electrically actuated emergency brake?
https://www.estopp.com
With the roll cage down tube and that I desire to have a foot rest for my left foot, there really isn't room for the stock e-brake pedal assembly. Could integrate a hand pull in the center console but that eats up valuable real estate.
Any downsides?
Appreciate any input.
Have a great day!
John
My Build Thread:
https://lateral-g.net/forums/showthread.php4?t=53320
Old 04-03-2017, 05:35 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
I have one but not hooked up yet,story hopefully someone will help with some pics.
Old 04-03-2017, 06:58 PM
dhutton dhutton is offline
I installed one in the Camaro convertible I did for my wife using C6 Z51 brakes. I had to temporarily defeat the safety connection that prevents the brake from engaging when the car is running so I could apply the brake while moving in reverse to adjust the brakes.
I'll probably use one again.
Don
Old 04-13-2017, 01:19 PM
67greengt 67greengt is offline
funny the mention of the pulling force being too light... I had an estopp in my car and it pulled too hard, actually bend the rear e brake backing plates and destroyed the internal e brake mechanism. One of the actuators let go when I was driving the car (low speed thankfully) and it locked up the rear wheels, ruined the brake rotor hats. I contacted E Stopp and they didn't want to make it right at all. Highly recommend not going with it, but thats just my two cents
Old 05-05-2017, 03:39 PM
vstol vstol is offline
not for that price
Old 05-05-2017, 04:07 PM
Goosesdad's Avatar
Originally Posted by dhutton View Post
I installed one in the Camaro convertible I did for my wife using C6 Z51 brakes. It works well but the pulling force was just enough to pass the state inspection. I had to defeat the safety connection that prevents the brake from engaging when the car is running so I could apply the brake while moving in reverse to adjust the brakes.
Don
Originally Posted by vstol View Post
not for that price
Thanks for the feedback guys!!!
Have a great day!
John
My Build Thread:
Old 05-05-2017, 05:50 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
What do you mean "one of the actuators let go"? With an E-Stopp system there is only one actuator which pulls the brake cables to engage the park brakes. When the park brakes are released the E-Stopp actuator is extended and there is no tension on the cables or the park brake mechanism. The comment above makes no sense.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 05-05-2017, 06:48 PM
dontlifttoshift's Avatar
I think he means one of the actuators in internal parking brake itself came loose and wedged itself inside the rotor hat.....I think.
I installed an eStopp in a car with IPSCO spot calipers and it worked quite well. Same unit, same car, now running a stock C6 internal park brake and it works flawlessly.
Donny
Old 05-05-2017, 08:19 PM
I've installed TWO E-stopps ---- both using the Wilwood internal brake drum rears -- works exactly as you'd expected it too. It's a great product and an even better idea!
Old 05-06-2017, 07:13 PM
carbuff's Avatar
carbuff carbuff is offline
Greg,
How did you mount the unit? At 600# of pulling force, it would need a fairly significant mounting point I would expect...
