Old 04-06-2017, 07:12 AM
silvrgt3 silvrgt3 is offline
Default ls3 525 supercharger
Anyone put a supercharger on a ls3 525 without changing the cam
Old 04-06-2017, 02:11 PM
slimjim's Avatar
slimjim slimjim is offline
I believe Angelo Vespi did this in his c10 built last year, he ran a Manguson charger.
NC
streamline 68 camaro
Build Thread here
Old 04-06-2017, 03:32 PM
andrewb70's Avatar
The ASA cam is not exactly boost friendly. It would be relatively easy to swap in a LS9 cam and it is only about $130...plus your labor.
Andrew
Old 05-20-2017, 09:22 PM
cjsgarage cjsgarage is offline
Andrew
Andrew is right. If your engine is a crate engine, the gaskets will come off and go on without leaking. The ASA cam has a much tighter LSA and would not be ideal for boost. Whereas the LS9 cam is cheap and would drop in. And you'd have a HotCam to sell. Potentially a zero money out of pocket transaction.. as long as you're willing to swap cams yourself.
I like wiring. No joke.
