Old 04-10-2017, 09:16 AM
BMR Sales's Avatar
Talking BMR Suspension New Product-Billet Saddle & Delrin Bushing Kits for 1 3/8" Sway Bars
Billet Sway Bar Saddle and Delrin Bushing Upgrade Kits for 1 3/8” Sway Bars
SMK013 - Saddle and Delrin Bushing Kit
BK076 – Delrin Bushing Kit
If you’ve installed one of BMR Suspension’s 1 3/8-inch handling sway bars or Xtreme Anti Roll Bars upgrade the sway bar mounts with a Billet Aluminum/Delrin Sway Bar Mounting Kit or 1 3/8-inch Delrin Bushing Kit from BMR Suspension. Most BMR sway bars come with formed steel sway bar mounts with polyurethane bushings. This gives you an effective sway bar mounting solution that limits the amount of wasted sway bar rate from bushing deflection. Under extreme loads, bushing deflection can absorb sway bar rate and allow excessive body roll. BMR designed its Billet Aluminum/Delrin Sway Bar Mounting Kit (SMK013) and Delrin Sway Bar Bushing Kit (BK076) to solidly mount the sway bar to the chassis eliminating any bushing deflection. Eliminating this deflection will reduce body roll and increase handling and launch consistency. Designed for max-effort street performance, drag race, and handling applications, the SMK013 or BK076 replaces the saddle and poly bushing or just the poly bushings if you already have the BMR billet saddles. The saddles and Delrin bushings are CNC-machined, giving you a perfect fit, and the strength to withstand any form of performance driving. BMR’s Delrin bushings are also greasable for smooth operation and long life.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
