Old 08-03-2006, 07:25 AM
67SSChevelle 67SSChevelle is offline
Default Shocks: single vs double adj??
I've decided to go with a coilover setup using some QA1's. I don't plan on autocrossing my car and I know any kind of any adjustment capability is better than a regular gas shock but I can't see the need to spend the extra $$$ for a double adj. shock. Any opinions otherwise??
thanks
Old 08-03-2006, 07:50 AM
Tony@AirRideTech Tony@AirRideTech is offline
Supporting Vendor
I am putting doubles on my 61 and I have also done quite a bit of playing with singles and doubles. If you are wanting that ninth degree of tuning I would say go for it.... if you are not going to use the adjuster and spend the time tuning them in... then dont. I personally like them though but it is really up to you and whether or not you are going to use them........
