Old 04-17-2017, 08:34 PM
Dr G's Avatar
Dr G Dr G is offline
Default 180 treadwear tires at a 200 treadwear Auto-x?
I am planning a new suspension build around wider wheels and tires. I have three tire sizes in mind: 305/30-19 (or 305/35-19) which I know will fit. 315/30-19 which I'm pretty confident will fit, and 325/30-19 which will most likely fit, but might get a bit tight. (this is on the front which is my limiting case)
Problem - the first and last sizes I listed are available in 200 treadwear. But the middle size, which is my preference, is only available in 180 treadwear (Michelin Pilot Sport Cup 2).
Question - if I opt for the 180's and then want to enter a Goodguys auto-x for example, will I be allowed to run at all? In some type of catch all class for people who don't fit any of the standard classes? Or will I be denied entry?
I'm not sure how the rules work, which is why I ask. I am not particularly interested in fitting into a class, as long as I can run.
Thanks.
Old 04-18-2017, 12:21 AM
Flash68's Avatar
Flash68 Flash68 is offline
Thinking that would be just exhibition at that point but I may not be up to speed on the latest and greatest from Goodguys.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 04-18-2017, 10:08 AM
Dr G's Avatar
Thanks Flash. Some research yielded this from the Goodguys website, though for 2016:
Most of my auto-crosses are with the BMW Club and POC. They don't care about treadwear ratings. There are few GoodGuys events near LA, so this is an outlier condition.
Old 04-19-2017, 10:07 AM
They'll still give you a time. It seems that treadwear ratings these days, especially with the USCA and Lemons/ChumpCar stuff, are somewhat based on sales and event sponsorship (ask Tire Rack), rather than actual tire compound. In other words, many of the 200-level tires would have been rated at much lower numbers a few years ago. My old Hankook RS3s (very popular in Lemons racing) were 200, but everyone says they should have been 140. The Nitto NT05s I just got look ridiculous, especially with that whole treadwear indicator thing . . .
Build what suits you.
Old 04-19-2017, 11:14 AM
dontlifttoshift's Avatar
The RS3s were 140tw and then were upped to 200tw when seemingly every race series (chump, lemons, USCA, GG, SCCA street classes) went to 200 as their spec number. It's marketing for sure, as the RS3s wore better than the then current crop of 140tw tires, aside from the Star Specs.
Heard from a guy whos cousins boyfriends uncle works with someone who lives next door to a guy that works at michelin that the Cup2 could easily be a 200tw tire but they don't care to play in that space. That's why they have the Rival.
To the OP, I would be willing to bet that RE71s in 305 would be faster than the Cup2s in a 315 on your typical autocross course......and especially at Goodguys where time between runs can be significant.
Donny
Old 04-19-2017, 11:43 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default 200 tires
I ran at the Goodguys recently this year with 200 rated Rival s tires out
back and Hankook dot road race tires in front (the Re71re rivals I had were hitting
the fenders so I changed them so I could run).... They gave me a time
before I broke the car... In the past I have run dot road race tires
all around and they showed my position but no time
As others have said the Rival s.. they now have a rival s 1.5, Bridgestone re71re
(I think is the best) but things change as Falken now has a new tire rated
200 are the ones playing with the numbers to make the tires work for the class
I have run dot road race tires at 40 rated with 200 rated tires
in the front and back and back and front and cannot tell the difference
on an autocross track... Drove that way to the good guys event in
the rain... then that is a different story
Bob
Old 04-19-2017, 03:44 PM
The Rival S 1.5 is only on sizes 255 and narrower. Or put another way, the 3 rib tires are now 1.5, the 4 rib tires are the same as last year.
There was a change in carcass design to sharpen up the steering inputs.
Donny
Old 04-20-2017, 09:57 AM
Panteracer's Avatar
Default 200 rated tires
Thanks Donny.. its hard to keep up with
all the changes these manufacturers make
I see the RE71re are now coming in 19"
Not sure how they determine what sizes to make
I used to run 275 and 315 17" tires on my firebird
as it was the same as the Corvette sizes for many
years. There were always a good tire selection
Now a days they seem to be all different
Bob
